A/C troubles and more....
Well, my battery was disconnected for about a month while I was getting some work done on my truck (02 Tahoe). My a/c wont blow on the #1 and #2 settings but will work fine on the last 3. Any ideas? Does something need to be reset? On another note, my foglights wont come on. There's power in the fuse panel but power is not getting to the harness itself where the bulb plugs in. I dont know if this is all related. Does it need to be reflashed to pick up the lights...I had factory fogs...
The Blower motor is easy.. it's the resistor pack on the blower.
Just go to partszone on line and order it, its mounted to the blower motor, if you pull yours off now you should see the green insulation peeled off of it.
RESISTOR, All Models 99-04 $19.06 $13.15
Don't know what work you had done but check the fog light ground. It may have been knocked off or is a bad location.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
