mpg in the tolet
I have A 2004 2500HD duramax 6.6 V8 was getting 16.9 mpg had a service done at 3000mi then the mpg droped off to 11.5 the dillership told me this was within the realm and threr is nothing wrong with it .
Is this right ? every one that i talk to about the fuel mileage tell me they are getting 18 and above .
The qestion is who is blowing smoke ?
If it dropped off after they worked on it I'd raise hell.
Also, the dmax fuel mileage gets better as it gets broken in. I have seen 23mpg on a highway trip and usually get 19-20 mixed driving.
Edit, 42,000 miles here 2003 LB7 Dmax/Ally
Edit again, Welcome to the site. :jester:
Is that actual calculated mileage, or what the DIC is telling you? The DIC is notoriously inaccurate.
Mine (with 45,000 miles on it) gets better than 12MPG pulling over 6-tons of camper trailer so your 11.5 empty is NOT OK! :jester:
04 8.1 here with a 6 speed. 14 is the best I can do, you should easily best that with a 6.0 litre.
I don't know...6.0 liter is working harder to pull that heavy rig around.
Heck my 5.3 in a 1/2 ton usually only gets about 13.5 mpg. in mixed driving.
Why are guys referring to gaser engines? (6.0 and 5.3) It's a 6.6 Duramax.
And NO that mileage is not acceptable. Most people pulling BIG loads still see 11-12 mpg.
I've been getting 11-12 while pulling a load. That kind of mpg while running around empty clearly indicates that something is wrong. How many tanks of diesel have you gone through with this kind of mpg?
Wow, that's bad or you have a heavy foot. Is that while towing? I get about 17mpg. The difference couldn't be that much different between a reg cab and an x-cab.
  • 4 weeks later...
My 2005 2500HD Duramax/Ally 4X4 seems to get 13-16 in town. This weekend I pulled my 10000 lb boat and was a little dissappointed. Mileage averaged 9-10 mpg at 60 and dropped down to 7.7 - 7.8 mpg at 68-71 mph, I was expecting better. What do you all think?
We're up to 1,200 miles on our 2005 2500HD LLY/AT/4x4. We're getting about 20mpg on the highway (calculated) and about 14mpg towing an 8,300lbs trailer. I am quite happy about that. My trailer is quite aerodynamic (looks like a silver hot-dog, if you know what I mean). I drive near sea level. The terrain is mostly flat, with slight rolling hills in some places. My first impression is that the DIC shows slightly below actual mpg if solo and a bit above when towing. My 454 gets about 14mpg solo on hi-way and about 9mpg towing. But I can certainly get the 454 down to 7mpg if take on real mountains.
My 2005 GMC w/ Duramax is getting nearly identical mileage to your '05 Chevy. I get 13-14 in town; Highway unloaded - 17; Pulling my 8,500lb fifth wheel at 65mph I got 7.5. I was expecting a bit more.
maybe with the 05s its that increase in power they
did.i have 04 2500hd cc d/a average around 20-22
highway,16-18 city,14-16 hauling my 9000#trailer
70mph. anything over 75-80 just give up trying to keep
track of good luck :lurk:
    MANGOAL
    MANGOAL
  • Who's Online   1 Member, 0 Anonymous, 479 Guests (See full list)
