2004 sealed chassis on silverado
are the 2004 chevy silverados font end sealed with no grease fittings?pif so probably a real good idea since jr at the quick lube shot my 99 ball joints to :and burst the seals
Nope, the '04's have grease zerks too! And a sticker right in front of the driver's sight of view that clearly states "NEVER TAKE YOUR TRUCK TO A QUICK LUBE!" :)
Yep,'04's have grease fittings, Just greased mine last week for the first time. :)
I believe there is a total of 11 zerks and it requires removal of the plastic "skid plate" to reach 'em all. I'll know in a few days how hard they are to get at.
If they're like the 03s then yes, the skid plate (more accurately the "engine shield" since that piece of plastic would crunch on anything harder than dirt) needs to come off.
You might want to switch two of the grease zerks with 90 deg. fittings which you can get at any auto parts store. Much easier, especially on the passenger's side to get to the fitting since the A/C compressor is in the way. You'll see what I mean when you get down there. There is/was a guide on here for finding all the zerks and which ones should be replaced with 90 deg ones.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
