Haven't seen this in a while
MoJo
Actually, they did sell the T100 in California in '98 -'99. Then, in the infinate wisdom of the corp. execs., they introduced the poorest excuse for a truck you could imagine; the Tundra. I have yet to know anyone who used it as a serious work truck that would buy another!
I've seen a few in my neck of the woods. wouldnt buy one for all the tea in china :thumbs:
  • 1 month later...
    Policeoff01
    Policeoff01
  • Who's Online   3 Members, 0 Anonymous, 784 Guests (See full list)
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
