5.25's in rear of X-Cab
todddd41
Once upon a time I found a pics or a link to pics on this forum where somebody had trimmed the sheet metal to put 5.25" round speakers behing the stock gtrills on a NBS extended cab. Problem is I can't find them now. Has anybody done this or know where to find these install pics? I'd like to look them over again to see if it's something I want to do before I buy speakers.
Would the 5.25's be much of an improvement over the 4x6's, and if I use 4x6's, should I use plate mount, or coax?
Thanks
Well you dont even need to trim it out. What you can do is make a spacer plate, so that only the magnet sticks through the old 4x6 location hole. Like this pic. See he just used a 1/2" piece of wood (MDF or 3ply will work perfectly). And the door panel has no interference with it at all! By the way, the speaker mounted is a CDT 5.25" coax.
Wow, I wish I was that smart. Do you know if the clearance issue changes at all with my truck being a three door?
Thanks for the info, I think I'll g with the 5.25's
This truck is a 3 door. Should be no issues with clearance. If you look closely, you'll notice that you have like 1.5" gap between the door panel and the inner door metal panel. Plus about another 0.5" space due to the speaker grille and how it concaves out a bit. So you have plenty of room to do what you want.
That was exactly the one I was thinking of. Thank you.
I see some discussion on using bass blockers on the stock speakers in that thread. Did you actually do that, and how did it work out?
I'm not using bass blockers, myself.
I have a Panasonic CQ-C9800U head unit. It has built in High Pass and Low pass filters along with Sub crossover. It does have an option to change the rear speakers into subwoofers just by turning the option on. The 5.25"'s just can't push the air like a dedicated sub can. You could notice it though, but it seem at the sonic level and not much at all at the "thump" level.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,357 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
