I just picked up the truck It's Still Not Fixed!
Well guys this girl is at the end of her rope.
The dealership has had my truck all this time, I just got it back today. They called their service tech in. After all their diagnosing, he replaced the left front bearing and hub assembly and they replaced both rear axel shafts. They did another front end alignment and charged me another $59.
THE TRUCK STILL PULLS TO THE RIGHT AND VIBRATES. :cheers:
I should have suspected the call he made to pick it up. He never said it was fixed. He told me what they did and said it was ready for me to pick it up.
I am so so angry. :smash: I think I swore all the way home.
Then my phone rang, I have a new GM Rep. Evidently he took over my case now. I told him everything that happened. He must have found out something about my truck from the dealership, because he seemed to expect I was upset. He wants me to take it back to the dealership. He said he would call them.
Once again I told him I wanted to know why the drivetrain shifted. I asked him now that the drivetrain is aligned, is that what's causing the pull or vibration. I also told him the mileage.... 35,913.
He said that he would work on a "component warranty" which sounds like they will only warranty the problem once it is figured out.
He said they are going to have to contact the regional manager.
I think it's time to sit down and count all the trips and attempts to fix this. I was pretty angry with this guy, I told him GM hasn't done anything for me as far as fixing this and telling me why it happened and if it will happen again. I told him I was totally disgusted with how this is being handled. It's been over 2 months now, and I still can't drive it.
Now I will have to put up with this jerky manager again. How long can this go on?
:lol: I really am sad.
It's just nuts, but you're sticking with it and it this point it's all you can do. I would push the time that you haven't been able to use the truck, etc with this new rep you have. Again, hopefully there's that light at the end of this loooooooong tunnel.
You must persevere. They want to wear you down. Just forget about the whole thing and go about living your life, with the exception of the time you spend face to face with the insulting parties. Save your energy for those opportunities to vent.
We're all pulling with you!
Thanks for your replies,
Is that all GM is going to do is just play games and wear me out? Will GM ever do anything? How long will this go on? Maybe I should just sell her. :lol:
If I remember the original post correctly, you had some major failure in the front end, correct? I'd ask GM to authorize taking the vehicle to an independent shop, that you know will do quality work (ask around). Find a collision shop that's well regarded and has all the latest equipment. You don't say if they checked the frame, but it sounds like the frame is bent. A reputable, competent shop will find this within the first day or 2. Argue that the GM shop isn't getting the job done right and maybe it's time to see if the solution can be found elsewhere.
Hi blue2kzr2 yes, I did have a major problem that every person I know has never heard of in my case.
July 15 the first dealership replaced the right bearing, and said all the noise on the left front of the truck was from the drivetrain shifting. He said they had to partially remove the engine and trans to re-align them and they installed new motor/trans mounts. No one will tell my why this happened, or if it will happen again. The truck never drifted to the right until after they repaired it. The vibration started in the beginning with the other problems. I have owned this truck since brand new, never been in an accident, never even towed anything yet or carried a large amount of weight in in it.
I just wish I new GM's intention and if my truck will ever be the same.
Lisa, I know you said you don't like the looks of the newer body style trucks but at this point I'd start persuing the Lemon Law for your state. Do whatever is in your power to get a new truck and just put up with the looks for a year or two and then trade it in when GM restyles the trucks. Having a slightly uglier truck that's not a lemon would seem like a pretty good trade-off versus a better looking truck that's a basket-case.
Guya71 at this point I probably would go for a new truck. I am so tired of going through all of this and not being fixed. I need a vehicle I can trust and right now I don't have that.
I am with asepgrad98, after all of this what are they charging you for? Whatever work is being done should be on GM including any associated fliuds or parts. I would point that out to the new rep. Since NONE of this was your fault you shouldn't have to pay a dime. I would also lean towards your frame not being the proper dimensions or out of alignment. This would possibly explain the drive train shift and whatever they "rigged" to fix it causing the vehicle to pull and vibrate. Keep after them you are moving up the ladder to people with authority to make the bigger descions. Best of luck.
Lemon law>>>>>>>Just tell the you want a new truck un the lemon law>.....
chuck
I've read a few of your threads, but I haven't seen what symptoms the trucks has.
The drivetrain shifted? WTF does that mean?
Something doesn't seem right here that's for sure. Take the truck to an independent shop, with or without the dealerships authorization. If they are gonna keep charging you $59 for replacing the wrong parts you will be better off to find out what the problem really is.
I can't believe they are charging you for something related to this!!!!
OR that you paid it! No wonder that they can't find the problem. Keeps you coming back.
Yep, as much as you hate to part with her, with your papertrail, you've got a pretty good start on the lemon. It may be time to head down that road and get yourself some peace of mind.
Hey everyone,
I know I shouldn't have paid for the front end alignment again. I will try to recoup that money especially since the truck had an alignment done in March. Then the one in July at the first dealer and now this one. To date none of their alignment have made a difference, laser or not.
I've had 3 people make a remark that caught my interest. All of them basically suggested the idea that the truck was dropped from a high place. I don't know what all they did on July 15, other than removing the engine and trans from the frame and re-aligning them, right bearing and hum assembly, and I also found out they replaced the intermediate steering shaft.(I thought they only greased it, GM rep said they replaced it????)
99-2door The only thing I can tell you is out of the blue my truck started having a screeching sound coming out of the right, the left side sound like you were hitting bumps when you weren't. Each day the left side got worse, until they were loud clunks, you only had to turn the steering wheel an inch to the left before all the noise started in the left. If you turned to the right, it didn't do it. My truck was bouncing/vibrating as well. After getting it fixed, the noises were gone, but the vibration was still there and she drifts to the right now.
I just hope someday I will find out what happened to my truck. I did suggest the idea to the GM rep that maybe we don't know the whole story from the first dealership, maybe something happened they don't want to share with anybody.
Gotta go for now guys, talk with you later.
    MASONV88888888
    MASONV88888888
  • Who's Online   1 Member, 0 Anonymous, 1,399 Guests (See full list)
    • My 2025 Silverado 1500 had to receive a brand-new engine (long block) under warranty last month at only around 16,500 miles. Before the replacement, the truck repeatedly displayed "Engine Oil Level Low" warnings, even though the Oil Life Monitor still showed around 50% remaining after about 6,000 miles since my last oil change. After seeing the warning several times, I checked the dipstick with the engine cold, and the oil level was completely normal. The next day, the message escalated to "Add Engine Oil." At first, I assumed it was just a faulty oil level sensor, so I brought the truck to the dealership. After inspecting the engine, they found internal cylinder wall scoring and ultimately replaced the entire long block under warranty. Before this happened, I was planning to install a 4-inch lift and suspension upgrade on my truck. After needing a new engine at just 16,500 miles, I honestly don't see the point anymore. I also contacted GM to ask whether my vehicle qualified for a buyback, but I was informed that it does not at this time. Anyway, this experience has left me with serious concerns about the long-term reliability of this engine. I sincerely hope NHTSA expands the current investigation or recall to include 2025 model and performs a thorough inspection of affected vehicles. My biggest concern is that these engines may fail shortly after the powertrain warranty expires. If GM truly stands behind this engine, then at the very least, please consider extending the powertrain warranty to 10 years for affected owners. That would go a long way toward restoring customer confidence.
    • Without exception but then I'm the odd duck, right? I know what goes into that test, how it is calculated and thus how to beat it. But EPA values are often not beaten by the general public and the government has in past years adjusted the means and methods to come to those values to more closely approximate "Joe Average".    The only real trick to beating that EPA average is don't drive like "Joe Average".    It's the same method you used to profit from "Economic Migration" and in doing so beat the 'stats'. But you, like me, are not "Joe Average".     The thing you don't seem to grasp is this "Purchasing Power Index" isn't forward looking. It doesn't predict what it going to be but looks backward and states what it was. They are not telling us what the THINK, they are telling us what they MEASURED. Example:    Wife says "I'm going to lose 40 pounds by Christmas". May she does, maybe she doesn't but the doctors office who weighed her when she made that statement and again at Christmas only REPORTS what the RESULT was. You and I can banter about what was possible and what aunt Tilly did till the cows come home but the result is the result. Arguing otherwise is.....irrational. That's all I'm saying. This isn't about:      What you are calling a 'Statistic' is a RESULT not a CALCUATION and as a result the RULE. Like gravity as a rule, it can not be broken.
    • Just wanted to say thank you for posting this. Years later, your thread is still helping Silverado owners.   I bought my 2025 Silverado 1500 in January 2025, and I've had what feels like the exact same rattle since day one. After reading your findings, I believe my truck has the same issue with the cable carrier contacting the rear sliding window. To be honest, I had pretty much given up on pursuing the issue. It wasn't until I recently drove another brand's pickup that I realized just how quiet their cabin was—and how noisy mine has been all along. On my truck, the rattle happens on almost any paved road, gets even worse on rougher pavement, and I can even hear it during braking and acceleration.   I actually referenced your thread when submitting my case to GM, hoping they'll recognize this as a recurring issue instead of treating it as an isolated incident. The reason I reached out to GM first is because my dealership told me they would need to keep the truck for at least two days just to diagnose the problem. I was concerned that even after two days, they still might not be able to identify the source of the rattle before giving the truck back to me. I had also asked a few dealerships about this issue during previous service visits, but none of them seemed to know what was causing it or had a solution. That's why I decided to contact GM directly first, hoping they might already have an official repair procedure or guidance for this issue.   I also hope GM eventually comes up with an official fix for this problem. I have a feeling there are many Silverado owners experiencing the same rattle, but most either choose to live with it or simply don't know what the cause is.   Really appreciate you taking the time to document your diagnosis. Your post is still making a difference years later.
    • I have 2 choices.
    • Do you have access to BP fuels? Some stations have Silver 91 E-0 priced the same as their 93 E-10.  There is a local Marathon with 90 alky free for $6 a gallon but I go down the road to BP for $5-ish. They also have a 100 E-0 but that stuff is $10 a pop.
