denali and tahoe running boards
are the 2001 and up denali running boards and the tahoe running boards the same? the reason im asking is i want to put the denali side moldings on my tahoe and was seeing if i would have to swap the running boards or not. or would it look stupid with tahoe running bourds and denali side moldings?
The Denali cladding and running boards have special matching shapes around the wheels. So the front of the Tahoe running board might look a little odd against the Denali front "mudguard".
Many aftermarket or even GM mudflaps will not attach to the Denali trim.
Nope,there not the same,totally different part numbers. :crackup:
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
