Avalanche Oil Question
Having read the Avalanche Oil consumption post...I went out and checked my oil level. (The AV has the longest dip-stick I've ever seen)!
Anyway, the oil was just below the 2nd dot on the stick! I am currently at 2300 miles.   :0
Should the oil level be "at" or "above" all dots on the dip-stick? :stupid: Does this reading indicate a "Low" level? It is still above the "Add" mark!
I also happened to catch (out the corner of my eye) a "white" plumb of smoke from my exhaust when I goosed the accelerator down while coming off a light one day. Should this be of concern or documented at my dealer?
Thanks
Brad in SoCal :D
I just went out and checked mine in my 6.0L   There are 5 holes on the dipstick with #5 being max.  My oil after sitting almost 12 hours was 1/2 way between #4 and #5 (almost full).  This is with almost 1900 miles and almost 4 months of very short trips and a couple hundred miles towing approx 8500 lbs.  I think mine is only down a few ounces....
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
