I need license plate ideas
chevelless502
I think i am going to be getting a truck this weekend and i need some plate ideas, its a 2000 GMC Sierra Ex Cab 4x4. Any ideas? i can have a number and up to 5 letters or 2 numbers 4 letters 3 numbers 2 letters.
Andy
How about just letters? like "SIEREX" or "00SERA"
0SERA0, SERA00, 00GMC (prolly been done)
Is it a 4.8 or a 5.3?
48GMC, 53GMC, 48SERA, 53SERA, GMC53, GMC48, SIERA, SERA48, SERA53
just a few for ya
just a few for ya
Its a 5.3 pewter in color with graphite on the bottom.
    Sothpaw27
    Sothpaw27
  • Who's Online   4 Members, 0 Anonymous, 825 Guests (See full list)
