splashguard fitment question
Just wondering if anyone knows which set of splashguards fits the 04 Silverado with fender flares. I know there are two types (with bowtie) one is contoured to fit against the fender and another is flatter. Which one?
Thanks for any help
vroten :D
Hope this helps.......from the website:
http://www.gmgoodwrench.com/accessoriesjsp...270226357231834
Custom Molded Splash Guards for 2004 Chevy Trucks Silverado
Without Fender Flares - Fleetside With Bowtie Logo, Front 12495822 $ 40.00
Without Fender Flares - Fleetside With Bowtie Logo, Rear 12495823 $ 40.00
Without Fender Flares - Fleetside With No. 3 Racing Logo, Front 12496982 $ 41.00
Without Fender Flares - Fleetside With No. 3 Racing Logo, Rear 12496983 $ 41.00
Fender Flares - Fleetside - With Bowtie Logo, Front 12498060 $ 40.00
Fender Flares - Fleetside With Bowtie Logo, Rear 12498342 $ 40.00
Sportside With Bowtie Logo, Rear 12497962 $ 40.00
Composite Bed - With Bowtie Logo, Front 12495822 $ 40.00
Quadrasteer - With Bowtie Logo, Front 12495822 $ 40.00
Quadrasteer With Bowtie Logo, Rear 12498055 $ 25.00
Flat with Contour Splash Guards for 2004 Chevy Trucks Silverado
Fleetside With Bowtie Logo, Front 12497448 $ 15.00
Fleetside With Bowtie Logo, Rear 12497448 $ 15.00
Fleetside No Logo, Front 12497447 $ 15.00
Fleetside No Logo, Rear 12497447 $ 15.00
Sportside With Bowtie Logo, Front 12497448 $ 15.00
Sportside With Bowtie Logo, Rear 12497448 $ 15.00
Sportside No Logo, Front 12497447 $ 15.00
Dualie With Bowtie Logo, Front 12497448 $ 15.00
Dualie With Bowtie Logo, Rear 12498327 $ 88.00
Yes they are factory flares. There's a big price difference between the contour and the flat ($40 versus $15) Anybody know any great big difference between the two?
Vroten :D
I went to the dealer and put on the factory GMC molded flares. They fit over the flare and encorporate the nylon anchors that hold the factory flares on.
I purchased my flares off Ebay and added them later so now everything looks just like factory :crazy: . The flat ones are cheaper but look that way too in my mind. They require screws into the metal to attach and I didnt want to do that.
my .03
:D
