My check engine light came on twice. Ive got a scanner an it says (P0751 shift solenoid A performance or stuck off) thats exactly what it says. Anyone have an idea what this means.
It indicates a shifting problem, the pcm has detected a problem with the 1-2 shift solenoid(or the valve is stuck or has bad seals) that has probably left you with either first and forth or second and third gear at some point
  • 4 weeks later...
