Stupid Ricer guys
FDNY-Denali
Where is the 'disbelief' smilie? What in the WORLD was that guy doing sitting on the hood of his truck going down the street!? Words can't say...
That was too funny. If I were there, I would have slapped him right in the back of his head.
    Policeoff01
    Policeoff01
  • Who's Online   5 Members, 1 Anonymous, 746 Guests (See full list)
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
