stearing shock for an o4 burb ?
Ive always put frt stearing shocks on my trucks, now my 04 burb 4x4 does not have one, do they have one that fits, and if so has nay body put one on yet?
Scott
Are you talking about a Stearing "Stabilizer"? (Shock mounted horizontal for dampening). If so YES. Not sure about a factory one but aftermarkets all day long. Try http://www.4wheelparts.com/4wp/errorPages/...s.com/store.asp or someone like that. Good luck. :D  :P
You mean a 'steering' shock? :cool: I couldn't resist. :bs:
I know the FabTech Steering Stabilizer kit WILL work on a stock GM Truck 1999-2005.
I have installed 3. 2 on lifted trucks and 1 on a 2003 STOCK silverado Z-71/
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
