I just got a web camera in the shop
Bharnz
Found it and signed in! Didn't have time to search through all of the buttons at work, the bosses frown upon us playing on the internet and not working.
    Sothpaw27
    Sothpaw27
  • Who's Online   4 Members, 0 Anonymous, 825 Guests (See full list)
