Generators
Mighty HD
After my 9 hour drive Thursday night to Ft. Lauderdale from Lakeland (BAD BAD traffic) to get a Generator I have decided that plywood, tarps, and generators are an investment in Florida now. I am sick of them.
Which generator is everyone running down here. I almost had to gun someone down to get a Troy Bilt 5550w
It should be enough to run the whole house except the central heat/air.
I know I can backfeed it through the dryer plug, but my sisters husbend said he could hook up a switch panel/breaker dedicated to the generator so if something happens/surges it will pop the fuse before it messes up the generator.
Start your opinions!
BTW--3/4" plywood is the BEST for your windows..it'll make a hell of a man out of ya putting it up, and it works well. :cool:
dont forget, if you do back feed it, you must shut off the main breaker or pull the main fuse. Not all generators are created equally, look at the quality of power. Some of the home center gens will harm your electroincs (like computers or tv's etc.) As far as the automatic transfer switch, that is only worth the money if the generator has the ability to start automaticly too. Meaining, electric start-remote start, self primed if gasoline.
One of the best gens out now is made by gillette and has a honda motor. just about $1600 for a 5kw
My folks have a Honda generator that they use 2-3 times per year when the trees in their area knock out the power. It will sit all summer (my Dad probably fires it once every two to three months max) and then runs it for 24-48 hrs when the power goes out. I'm not sure what model it is however.
You definitely want to bring the power in through a separate fuse box. Take the time and do it right. Isolating it from your main breaker will allow you to turn off your main breaker and not accidentally run power up the line to the power crews working to repair the lines down the street. It will also allow you to keep power from running back to your generator during when your street power is working.
I'm not sure if I'd spend the money on a unit large enough to power almost everything in the house. Then again, if I had one for around here (Seattle area), I would only need it for 2-3 days max. GF7PE is right, the power you get out of it might not be clean enough to run sensative electronics (unless you can put something inline from the fuse box to clean it up). I would maybe just put my money into the best generator needed to power my fridges every hour or so and any other critical items. One thing I have learned however, is most of the generators have a pretty small fuel tank. If I was to set one up right, I'd bring in a larger tank so I wasn't having to fill it up every 90 minutes.
Good luck
To bad your not on the northern end of Rt 1(Maine). I have a 5500 watt deisel generator that is electric start and on wheels. Runs eithr 230 or 115 volts at 60 cycles, great for the whole house, yes I've even run the puter off it. I would definately install atleast a transfer switch if not a genset panel. That will keep you from accidently frying the power crews when they are working to turn the power back on. BTW the deisel generator ids for sale, $1400.. only has 1.5 hrs on it.
The troybilt that I got claims to have 10 hrs of runtime @ 50% load. I'm sure ti will be either better or worse than that. I mainly got it for the fridge. This last hurricane I lost a ton of meat, and other frozen items. The other 2 hurricanes didnt knock out power, this was the first time in the 4 years that we have lived here that it has gone out. With that in mind, and the cost of the meat, I just assume buy a decent generator. The 5550 got a consumer reports "best buy" and I've read other places it's safe to run a tv, etc. I do believe it will even run the hot water heater. I have to check the element sizes first though. I will also run a small el-cheapo window unit so we can sleep @ night if the power is off. A nagging wifey isnt a good thing...lol
Hopefully in the next week or so I will get a manual transfer switch, fuses, etc to safely wire it into the house. I will run it in the utility room or lock it in the back of the truck against my bedroom window in the backyard. The utility room is detached from the house and you have to walk through the carport about 10ft to get to it. I think I can open the windows (about 7ft off the ground)_ and not worry about someone stealing it.
We bought a used Coleman 4000 watt ebay special for $400 shipped. Bought this one because it has the old style flathead Briggs 8hp on it and I know the small Briggs L-heads inside and out. Back fed through the dry plug it fed a big freezer, a fridge, tv, 2 small fans, and a small window unit AC for ~105 hours. It burns a little oil but thats nothing a good freshening wont fix.
The only reason we bought it was for power in the pits at Daytona, didnt expect to use it for this. Well worth the money.
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 768 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
