BMW new Diesel's
SnakeEyeSS
the new 6 cylinder's BMW is making for their coupes, sedans and sports cars are wicked. they are bi-turbos: a small turbo for low speed, and a bigger turbo for higher engine speeds:
they make 272 HP at 4,500RPM(over 90HP per liter)
they make 390 ft-lb of toruqe at 1,500 RPM. that's more, lower, than the new LS2!!!
they max at 416 ft-lb's at 2,000 RPM.
They will perform better than s their comparable gas powered engines, for instance: at a stoplight contest the upcoming 535d(inline 6 diesel), will roast an 545i(320~ HP V-8).
:thumbs::sigh::)
if they stuff these babies in the X5(especially if they make V-8 variants), you'll be able to buy a U.S.A. built, over-engineered Ultimate Towing Machine(for small to medum stuff,; Automobile Magazine stated a feew years back that the long-term X5 was more stable pulling racing go-carts traliers than their personally owned Surburban).
Not to take awya fromn GM trucks, but more and more of them are being buiilt oversea's, while German and Japanese companies are pumping more and more job's into our economy. Go figure
Is Volkswagen doing the same with their cars as well? I had heard from several car e-zines that VW is going bi-turbo diesel in as many of their cars as fiancially possible.
  • 3 weeks later...
    Sothpaw27
    Sothpaw27
  • Who's Online   5 Members, 0 Anonymous, 722 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
