Hey, Kids.
El Duderino
I've been looking for a good forum to learn more about my '01 Tahoe and somebody posted this one today on corvetteforum.com. Thought I'd check it out and liked it enough to register. (Bummer somebody over here already got "my" username. LOL.)
Looking forward to it.
You've Came To The Right Place!!!! This Site Is Wonderful And The People On Here Are Great... What More Can You Ask For!!!! :tear:
WELCOME TO THE CLUB!
