Any Kawi jetski riders??
99Silver6.0
That thing looks awesome, and would certainly be a kick in the wetsuit to ride.
But this:
This Supercharged 15F looks Mean and  is a real fire breather, pumping out 330 HP on the Dyno. Yes I did say 330 HP? Which is more then a lot of hot rods put out.
:tear:
I don't know of any "hot rods" that put out that little power...Unless it's a ricer. :loser:
But this:
:cool:
I don't know of any "hot rods" that put out that little power...Unless it's a ricer. :flag:
Yea I know. I didnt write that wonderful little article. But from what I read in Watercraft Illustrated its a pretty dam fast ski.
  • 3 months later...
My husband and I ride and are looking into racing this year...woohoo! We have nothing but Kawasakis...STX-R 1200...STX 900...Ultra...and a recently aquired (free)Kawasaki stand-up that needs alot of work to get back on the water. :loser:
Gotta love it. Im gonna give it a shot this year too. Just one race at Smithville lake this summer. Friend of mine around here has a few STXr's. He said he'd let me ride one of the piped skis. Should be interesting.
