Took it out to the Mud Hole...
It rained quite a bit here in phoenix today. So I decided that today was the day. I can't believe how well the truck did even with the stock tires on it. Is it just me or is the frontend on these things got a posi or locker or something cause i mean no matter what both tires in the front would spin no matter what. I know the back is got a posi or locker or something. But nevertheless the truck did great couldn't imagine what this thing would be capable of if it had a lift and beffier tires on it. Oh and could someone specify the difference's between a posi, open diff, and lockers. Thanks in advance guys. :mad:
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
