speaker replacement
  • 1 month later...
did u figure this out? i have the same issue-- the tweeters are popped out of the hole and dangling by the wires insode the grille... ideas to open it up and fix?
mb
yes i did there ,are only two screws holding the panel on.there is one inside where the window and door locks switches are .look with a flashlight on the side of the panel of the switches there are two little slots or holes that is where you push in with a flat screw driver then the panel lifts up .then you will see the one screw there .the other one is where you put your hand to open or close the door you can see that one real easy .then the whole panel pulls up .good luck
    rayredbone
    rayredbone
  • Who's Online   3 Members, 0 Anonymous, 304 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
