2003 D-MAX/ALLISON For Sale
jstwkd
I Just bought a new 2005 Crew cab D-Max..So I am selling a complete motor trany package.The trany is a 2 wheel drive Unit.I have everything under the hood,Atatched to radiator support,And complete dash and everything under or bolted to dash..A gas tank and lines,exhuast,all electrical and computers in cab and motor.We are talking every single friggin peice...
It is out of a 2003 C3500 dually.With 19,222 original miles.I have the odometer and computer to prove it if you would like me to.
I am asking 6500 OBO Please feel free to make me an offer.
Email me at [email protected] or pm me here..
If you email me please make it clear in discription that you are talking about the D-MAX.If I dont recognize it I may accidently delete it.
I have some pix upon request
Thanks
  • 3 weeks later...
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
