'99 LS Auto Door Lock at 15 mph...
I have a '99 LS Silverado.. That does NOT auto lock the doors at 15 mph.. should it ?? Is it an option that can be added ?? If so ... HOW???
Thanks...
Dex, I believe it should lock if you want it to.  It should tell you in the manual how to enable and disable the autolock feature.  If it is engaged you have to either push the button on the arm rest or pull the key about 1/2 way out to get it to unlock...
All he manual says is that "the door will lock at 15mph"  does not say how to enable or disable....
The truck is used... maybe the previous disconnected something....
Anyone got any ideas ???
This is out of my 2001 manual and I think it is the same for '00.  Try it on your '99
1) With ignition off: pull back on turn signal lever (toward you) and hold it for the next step.
2)Turn key to run then off twice then with the key in the off position release the turn signal lever (you should then hear the lock mechanism lock and unlock.
3)Press the lock side of the door lock switch once and then the unlock side twice.  (you have 30 seconds)
4) to exit program mode turn the ignition to "run"
This will lock the doors at 15 mph and unlock them when the key is removed from the ignition.  It works on'00 and '01 trucks, maybe it will work on yours...
Good luck
My 99 locked at 15mph, you couldn't program it yourself the dealer could disable it or enable it for you.  Not sure if it was 2000 or 2001 when the locks changed to being able to be programmed by the owner.
I had a 99 Sierra and the dealer had to do the bypass in the computer. You could have dealer re-program the computer the way you want it. In 2000, the locks became user programable.
For all those who answered.. thanks..
The answer to the question is this..
on the '99 the dealer has to reprogram the whole computer.. I took it to a dealer and they had to reload the entire program for the body control module.. not just a quick thing.. it took him about 25 minutes to do it... the '00-'01 have the user programable ... he also told me on the '00-'01 there are a ton of UNDOCUMNETED things u can disabale enable reconfigure using the dome override.. He would go pass that though..
Again.. Thanks for the help...
I know that pushing the dome overide button 4 times you can disable the DRL's, but I wonder what all the other "undocumented" things are...
I was querying him about just that and he would not give any information..
I would think they would be in the service manuals somewhere...
But who knows....
My 01 auto locks at 20 mph.  Remove the key from the ignition unlocks the doors.  MY dealer/salesman programed it for me before taking delivery.
Quote from Stepside Z, posted on Sep. 17 2001,15:57
Shanners,
Did the DRLs come on again after you shut the truck off then restarted it?
Yes the DRL's come back on when you shut down and restart...
Dex;
 You can have mine!  They are user programmable and I turned em off....didn't like having to pull the key out to get out of the truck!
(Either that or hitting the unlock button)
CapnDean
    • Was all the way down to $3.69 a gallon but then jumped back to $3.99 just because for some reason.   Diesel floats between $4.80's to $5.10ish a gallon. I even saw Diesel #1 for $6.09 today but nobody in there right mind even buys that in the summer.
    • Mine just keeps lagging or getting stuck on the reverse camera. When I turn off the truck, get out, and close the door it will still stay on. It’s very intermittent and I would not be able to duplicate the issue.
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
    • Just wanted to get a idea of how many of you still have problems with your radio cutting out during the first few minutes of driving, my 2024 GMC Sierra still does this after a little over 2 years of complaining to my dealer about it, and OTA updates no longer complete, the check for updates in settings is greyed out for the second time while trying to install a update, my dealer took about a week to play around with it the first time this happened, and somehow got the check for updates to work, even though it would always show system is up to date when I knew it wasn't, now again 1 month later its greyed out again when the OTA update N25-F163BU tried to install, which ironically is the update to help with reliability of future updates.
