Tire change/reflash pcm
If I go from the 245/75 tires on my 2004 Silverado 2500 HD to 305/70's, do I have to buy a Hypertech just to reprogram my speedometer or can I just go to the dealer and have them do it? Will they charge me? Thanks!
If you take the truck to the dealer you can have them change it but instead of telling them the tire size tell them the circumference. I have heard this works. The other alternative is to get a Wester's PCM which is the way I went along with many others. Having the extra power is a major benefit.
My local Stealer will do the change for $75.00.
Peter is right. If you tell the Dealer to program for 33" tire you will be wrong. The ABS/Speedo and Tranny Shifts will still be off. A 305/70r16 cpmes out to around 30-31".
In the HyperPing Manual it explains how to correctly meaure tires. If you want to know I can post how.
I have question about this: If you only go 1/2" to 1" bigger or smaller from stock wheels w/tune does it matter or will need to send PCM for repro
Nah,
I "think" the only noteable change will be the transmission will shift a few RPMS later than usual.
Thanks. I'll check with my dealer when the time comes, but if it's $75, I'll just see if I can get a used Hypertech or some other PCM tune. BTW, I thought that the 305/70/16 ended up being 33" (according to the tire manufacturer's listing). I appreciate the quick replies! Love this board!
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
