Adding factory keyless entry, 02 TB
My wife's 02 Trailblazer was built without factory RKE. Is it possible to add the correct lift gate module and get the remotes?? Would this be all I need? I checked into this some, and found there are 3 different RKE LGM's, but only one tailgate harness. Any info greatly appreciated!
Dave
    Brendan C
    Brendan C
  • Who's Online   3 Members, 1 Anonymous, 1,035 Guests (See full list)
