GM upset about Z06 leak
Chris97K1500
Some of you all probably already know about this, but GM is investigating who took pictures of the new Z06 and engine that's going to be in it. DigitalCorvette's.com has the story if you want to read about it more. The pics must have been legit or GM wouldn't have cared about it. Chris
Makes ya think doesnt it. Unless GM is making a stink about this just to make a scene.
    Sothpaw27
    Sothpaw27
  • Who's Online   4 Members, 0 Anonymous, 825 Guests (See full list)
