R & D Accessories
Just bought the upgrade special that they have.  It all comes with Fog light controller, Door unlock controller and a Headlight controller.  Hopefully Ill get it next wed. so that I can put it in on my time off.  Cant wait to get it installed. :thumbs:  :D
here's the site.  R & D Upgrade Special
Wow, then you can be another light blazer coming at us - just kidding, have the kit also, trying to find time to install - post results - parts look pretty good - instructions almost make sense.
Yep Tom was planning on taking a gander at your installs before i start on mine home that my truck will fit in the garage or i will take me for ever to get done or a lot of beer.  Thanks for the link.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
