4L60E Slipping in O/D
This has been an on going problem. Once the trans warms up or if you really flog the truck, the trans starts slipping in O/D (evident by the tach rising and speedo not, if you blip the throttle). If you leave it in O/D, the engine light comes on and and the trans goes into limp mode. If I put it into 3rd before the light comes on, everything locks up and the trans works fine.
I changed the fluid and filter and put in a bottle of Kleen Flo Auto trans conditioner. This has helped a bit, but still, if you really flog the truck, it'll start slipping again. So I've been driving it 3rd most of the time.
I have read else were in this forum that this is caused by valve body wear, but after 70K with a truck that is typically driven like a car?? That's pathetic!!
I checked the forum at LS1Tech looking for the same problem but most (if not all) of the slipping problems I noticed there were do to racing, definitely not my scene.
Anybody else had this experience? Is changing the valve body the only recourse? If so, what's involved? Any do's and don't's?
Thanks in Advance,
Derek
What code is coming up in the computer? This will tell you if you need the shift kit or not. If it is the P1870, this can be fixed with the Trans-go shift kit. Delivered to your door for about $55 and a half days work to install. Not bad to do if you are familiar with a TH-350 or a 700R-4. If this is your problem I would suggest ordering a new seperator plate and a aluminum piston at the same time. Check out www.bulkpart.com. They have most of the right answers and great prices!!
Mike
The codes I had were P1870. This translated to two different things, transfer case broken (auto Zone translation) or Transmission slippage, my problem. email the guys at www.bulkpart.com, describe the problem and they can halp you with parts. They are knowledgeable and friendly. Oh yeah, and they have great prices!
Mike
  • 2 months later...
Hi All,
Just thought I would leave an update. I finally got a chance to install the HD2 kit on Friday afternoon. (Been traveling with work and have hardly been home since November).
This is a fantastic kit, trans works awesome now, all shifts are firm without being harsh, no more codes, etc. Everything inside seemed fine when I took it apart, fluid wasn't burnt, so I think all of my problems were control system related.
I did find that one of the spool valves was misassembled from the factory, don't know enough to say whether this was part of the problem.
So with the money I saved from having somebody else fixing my trans, I bought a 9000 lb hoist (where has this thing been all my life?!?!).
Thanks to all that responded to my post.
Cheers,
Derek
Glad to hear that you got the problem fixed. I have found that most tranny problems can be fixed by some sort of shift kit. Maybe I should start installing them for people in the area. Anyway, I am glad to hear that all is well and congrats on saving all the money on the repair! That is the best part.
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
    • Grommets with the right cement should be perfectly fine.
    • This is going to take allot of Assembly
    • Why do they have the gas 10l80 opening at 145?
