adding power door locks
I have the basic truck, and would like to add PDL so I can get a remote lock-unlock for it. Has anyone ever done this? And does any vendor sell just the remote door lock setup without having to get an entire alarm system?
2 years ago I put keyless powerlocks on my truck. I got a varient kit from Jcwhitney. Came with everything you need to switch from manual to power. has worked pefect Was like $80 with shipping..
Was very simple to install, took maybe a total of 1 1/2 to 2 hours.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 970 Guests (See full list)
