GM TSB on clutch fan replacement....
I have a '04 GMC Sierra 2500HD w/plow prep package. The truck gets very warm with the plow on (230 degree range). I have heard that there is a TSB that is specific to this problem.
I was able to find this on the web:
TECHNICAL SERVICE BULLETIN: MFG Bulletin Number: 00678C
MFG Bulletin Date: 20040101
Component: ENGINE AND ENGINE COOLING:ENGINE
Details: ENGINE OVERHEATS ON VEHICLES EQUIPPED WITH RPO VYU SNOWPLOW PREP PACKAGE. *TT
MCS Check Date: 20040614
But I am wondering what information to I bring to the dealer??? I would prefer the actual bulliten #, and any more information.
Thanks to all who reply!!
Engine Overheating (Replace Fan Blade Clutch Assembly) #04-06-02-006 - (Jul 27, 2004)
2002-2004 Chevrolet Silverado 4WD 2500 Series
2002-2004 GMC Sierra 4WD 2500 Series
with 6.0L Gas Engine (VIN U -- RPO LQ4)
and Snowplow Provision (RPO VYU)
Condition
Some customers may comment that the engine is overheating. This condition mainly occurs on 4WD 2500 series models that are equipped with a snowplow.
Cause
A lower fan clutch disengage speed, resulting in insufficient airflow passing through the radiator to trigger fan clutch engagement, may cause this condition. The snowplow may also contribute to interrupted grille airflow, which results in the fan clutch not sensing the warm air coming off the radiator and consequently not engaging the clutch.
Correction
Replace the fan blade clutch assembly with a new fan clutch that has a higher disengage speed. Refer to Fan Clutch Replacement (SI Document ID #642620) and the applicable part number below.
Parts Information
Part Number
Description
Usage
15710101
Clutch Asm, Fan Blade
4WD 2500 and LQ4/GT5/VYU
22149877
4WD 2500 and LQ4/GT4/VYU
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
    • PCM?  These don't have a "PCM".  Powertrain Control Module.  They have an ECM (Engine Control Module) and TCM (Transmission Control Module).   Do you mean update the radio?     You can check what version you have in the settings page.  Should be Y181 but there might be a newer build they can update it to.
