4x4 goes to autotrac
i have a 2000 Blazer 4.3 and when i put in four wheel high it goes into autotrac.
Is it true the there is a self dianose bye grounding two terimals in the connector under the dash and if so does anyone know witch ones...
Help please
chuck
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
