I want a new horn
I'm looking for a unique horn.  One that I can honk when I see someone I know.  I don't want to honk my normal horn in traffic and cause confusion if I honk when I see someone I know.  (I have a friend that can hook me up with an old train locomotive air horn if I REALLY want someone's attention.)  :) I like my uncle's "aaauuuuga" horn on his grand prix.  Perhaps a cow "mooo" or "General Lee" horn.  Does anyone have ideas or better yet places to look and "hear" the horns of choice?  All suggestions and amuzing jokes are welcome.
JC Whitney usually has a good supply of novelty type horns...  most are electric so you don't need an air compressor.  I'd check there first.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
