What's up people
Jefh328ic
hey guys, I'm new to the forums. I was browsing for some info about performance products, and I decided to join in. My name is Jose and here is my truck :smash:
oh yeah I also own a 328 convertible
    Policeoff01
    Policeoff01
  • Who's Online   3 Members, 0 Anonymous, 784 Guests (See full list)
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
