Black Escalade
Just to kinda get this thread going, I want to make it clear that if your crusing through this site and you own a black escalade, or any escalade, I demand you to sign up and post some pictures. :) I have been drooling over one for a long time.  Oh, I also want a ride if you live near-by.
They (caddy) had a black escalade at the show in Pittsburgh...   If I had known you wanted pics I would've taken them.  sorry man....  I left the show with about 15 pics still available in the camera.
Thats ok.  I have seen plenty of pictures, and even them in real life.  What I want now is to own one.(well, my parents to own one)
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,163 Guests (See full list)
