Loose Steering Wheel?
The steering wheel has some play on my 89 C1500. It seems to be in the column and the wheel moves ~2" vertical and ~1.5" horiz. I searched for topics and only found one Here . 99-2door and topo4u2 described what it is, but how do I get at the bolts to tighten them, I have tried before, but it got loose again soon after.
Any help is greatly appreciated.
Let me guess..TILT column right?
If it is you will have to dis-assemble it part way,Steering wheel, lock plate, turn signal switch, and the tilt tension spring....a repair manual could could come in quite handy here if you've never done one before....then there are 3(or 4 I can't remember exactly) bolts with torx heads that need to be tightened...I used to pull them out and put LOCK-TIGHT on them and re-install them AT A TIME (a magnet came in handy in case I dropped 1 :seeya: )
I did this without removing the column from the vehicle....GOOD LUCK
You're right, it is a tilt column.
I'll try this when there's a few days where the truck won't be needed.
The same thing has been happening with my car, so if this works you'll have helped on 2 vehicles.
Thanks
    ballencd
    ballencd
  • Who's Online   3 Members, 1 Anonymous, 664 Guests (See full list)
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
