Torsion Key Products
I am trying to level out my 01 Suburban 2500 with Autoride. I was thinking of doing the green key torsion bar conversion but I wanted some opinions first. Does anyone see a big advantage in the following products over just the GM green keys? I know one of the kits has shock extensions, which I can have made locally.
Thanx in advance, Craig
Suspension Maxx
Off Road Unlimited
Truxx Lift
just more money. have you tried adjusting them with the factory keys yet? most people spend the time and money for different keys when they can just tighten the ones that are already in there,
Yep, Valsport has it right. I have an 02 3/4 Ton Sub with Autoride and the purple keys to which I had the front end raised so the truck was level. Don't forget to get a wheel alignment after you jack up the torsion bars.Since that time I have installed an RCD lift kit made for an autoride truck. There are only two companies at this point in time that make lift kits for autoride trucks and that is RCD and Fabtech..Hope this helps :seeya:
    JustusTX
    JustusTX
  • Who's Online   4 Members, 0 Anonymous, 676 Guests (See full list)
