I got a 1500rcsb and i would like to put a console inbetween the bucket seats, I like the denali one, but I have the 4wd controls on the floor. Anyone have any ideas?
the denali one won't fit with the t-case lever on the floor either will the silverado LT style
The OBS trucks and SUV's had a center console that did not extend all the way to the lower dash. Check Ebay out there is alway some on there.
The 99-02 Silverado's consoles where two pieces, you could just put in the console and leave the extension off. Just an idea
What color's your interior? I have a grey cloth jump seat with the fold down console that would bolt right in...I started a thread in the For Sale/Wanted section. If you click on the link under the picture in my sig and go to page 4, you can check it out. I also have a grey 2 piece console that I'd be willing to split up, but I don't have the bracket to bolt it to the floor, and I'm not sure that even just the half would clear the manual 4wd control without modification.
The dealership told me a 2002 denali center console wouldnt fit or work in my 2003 truck.
I replaced the lower dash on my truck and the console bolted right in.
If you cant modify it or get it in some way you can always do a custom console. :D
That won't work in atomoverride's case since he has the t-case shifter on the floor.
My case? you mean that other guy. Anyways like I said...something can be customized I am sure of it. Just depends on how much money your willing to spend.
But to get the Most bang for the buck, I would just get an older 2002 yukon centerconsole just the back part. That should be good enough.
yeah, my mistake, I ment in GMracers case.
just goto ebay! that place rocks, I got the backpart of the denali console for 200$. then I called in a favor for the front part. Just bought the dash pieces from the stealership and got an employee discount then had the interior guy cover them in suade to hide the fact they are off by 1 shade of grey.
then being the wild and crazy guy I am I had him suade the headliner, and replaced all the parts in grey instead of that brown crap.
Where could a person get a denali console ?
The Denali Midnight auto parts store.
Just kidding, you could call a local salvage yard, if they don't have one they could always put it on the hotline to other junk yards and find one.
  • 1 month later...
Anyone have the GM part numbers for the center console....
Dont wanna hijack the post but dont you need the seats with armrests ?
I wanna upgrade to the console on the floor also , can this be done ? i have a 2wd
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 410 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
