Bad Gas???
Hey guys, filled up the ole tank the other night and the next morning the truck starting running real bad and then the SES light came on. I'm thinking I might have got some bad gas? I'm hoping that is all it is. I'm planning on changing the fuel filter tomorrow. Was just wondering if you guys have used dry gas in your tanks and if so what brand you recommend?
the ses light will come on when a dtc is happening or has set a hard code. find out what the code is first. Probably just a coincidence you fueling up. I believe autozone will pull codes for free.
Definitely get a code first, but I wouldn't rule out bad gas...seen alot of it in the past, especially in the winter months. If you do suspect gas, you're gonna have to get a fuel sample. Oh yea, a bad load of gas can cause all sorts of trouble codes...random multiple misfires, system too lean, etc.
Can't recall the name, and can't find it on the internet, but Autozone sells a gasoline moisture remover. I had a similar issue come up and they Autozone droid suggested to add the moisture remover. I did and remarkably, performance improved and after a fresh tank, my '03 Z71 was back to its old peppy self.
Man, Ive heard the name Sea Foam more in the last couple days of reading posts on here than I have in my whole life live a mile from the ocean! LOL What the hell is this stuff? I gotta check it out..... :fume::cheers::D
Man, Ive heard the name Sea Foam more in the last couple days of reading posts on here than I have in my whole life live a mile from the ocean! LOL What the hell is this stuff? I gotta check it out..... :fume:  :cheers:  :D
Do a quick search and you'll find a ton of info on SeaFoam. It's basically a fuel/oil additive intended for cleaning. I use it to clean the induction system on my truck by running a can through the power brake booster, you can also add it to a tank of gas, and some like to add it to the engine oil as a sort of crankcase flush...(personally I don't like to add anything to my oil, I change it often enough and use Mobil1)
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,017 Guests (See full list)
