FS: parting 95 6.5L TD engine
99-2door
I just bought a 95 K3500 SRW 6.5L TD with auto.
The truck had a smashed grille and the aux. oil cooler was damaged. I bypassed the cooler and the engine starts and runs fine, shows no codes. There is a slight knock in the lower end. Because of that, I would consider the short block as rebuildable and not a ready to install engine. Runs fine and has good oil pressure, but I would go over everything before going to the trouble to install it.
I am installing a Vortec 5.7L so I am taking the 6.5 out.
The truck has 153,000 miles on it, seems to have been well taken care of. There are receipts in the glovebox that show on 10-18-2000 at 109568 miles the PMD and waste gate control solenoid were replaced and on 8-16-2001 at 118881 miles the fuel pump relay was replaced. That is the only history I have on the engine aside from the fact that it starts quick and runs well now.
So, list what parts you need and I will get them listed with a price.
Every part concerning the engine is available, including the turbo, radiator, electrical harness, dash harness, PCM ,etc.
Post here or PM me. Thanks
