NO CHILD LEFT BEHIND TEST
bummed-n-Md
In response to President Bush's Federal 'No Child Left Behind Act"
(NCLB), it is proposed that students will have to pass a test to be promoted to the next grade level.
In the hope that this proposal will be uniformly adopted by all of the states as well as North Carolina, the new test will be called the Federal Arithmetic and Reading Test, or FART.
All students who cannot pass a FART in the second grade will be retested in Grades 3, 4, and 5 until they are capable of passing a FART score of 80%. If a student does not successfully FART by grade 5, that student shall be placed in a separate English program known as the Special Mastery Elective for Learning Literacy, or SMELL.
If, with this increased SMELL program, the student cannot pass the required FART test, he or she can still graduate to middle school by taking another one-semester course in Comprehensive Reading and Arithmetic Preparation, or CRAP.
If by age fourteen the student cannot FART, SMELL, or CRAP, he or she can earn promotion in an intensive one-week seminar known as the Preparatory Reading for Unprepared Nationally Exempted Students, or PRUNES.
It is the opinion of the Department of Instruction for Public Schools (DIPS) that an intensive week of PRUNES will enable any student to FART, SMELL, or CRAP.
This revised provision of the student component of the House Bill
101 should help "clear the air" as part of the "No School Left Standing" Act.
:D
  • 1 month later...
    • These show the problem and symptoms, and I explain things too. to clarify again, I did not change over any computers or wiring (with the exception of the map sensor). All of the computers and wiring are original to the 2010 vehicle   video 1 - background info/explanation and part of the problem   video 2, idle misfire   I think the reason that the MAP sensor is reading High is because the engine is misfiring so there is less vacuum...   Additionally there's a p0102 for the MAF low frequency, and a p0108 for the map high voltage.        Again, apologies for the somewhat long-winded explanation, it's a rather difficult problem to explain without going into the details.
    • You'd want the Pulsar to be safe.  That was the first product that worked for 10 speed trucks that they came out with.   Range Technology 22451 Pulsar LT for 2019-2022 GM Gas Trucks     That said, in the features description of the RA003B, it does list it working with 10 speeds.  However there are reports that the RA003B can cause some drivability issues on early 10 speeds.  So the Pulsar is the safest move IMO.      Range Technology RA003B AFM/DFM Disabler   Features: Range AFM/DFM Disabler keeps you in full power 100% of the time Simply plug into your onboard OBD-II port and it instantly begins working to eliminate the AFM system Disables Auto Start/Stop Blue LEDs The Range AFM/DFM Disabler does not reprogram factory ECU Works in hundreds of applications, 2007-2022, including 10-speed models. Leaves no trace, unplug it to return to factory settings Virtually no battery draw Fits all V6 and V8 General Motors (GM) active or dynamic fuel management vehicles, includes cars, trucks, and SUVs This device does not support the 2022.5+ Refresh model trucks or 2021+ SUVs To confirm your 2022 model truck is compatible with this unit, check your VIN. The 12th digit in an early model must be a '4' or lower Made in USA
    • I have a 2019 new body style high country with a 6.2l L87 and a 10 speed transmission code MQB. Looking for a disabler that is compatible. Most show it’s not. I watched a video on utube from Dons Life that says Ranges RA003B is compatible but when you go to Ranges website and check compatibility it only has a 8L90 trans listed which is an 8 speed.  I don’t want to buy the wrong one. Anyone have any experience with this situation?
    • This actually happened. Be careful where you get your information re: gas price trends.
    • I understand the principle...you don't want to spend $150 for a $0.02 piece of plastic or a little screw and perch thingy.   But this is a problem that looks like it can be reliably solved with a zip tie.   That might hold you over until you can score one at a pick-a-parts yard.
