hid conversion question
question with problem. sypnosis, installed a set of h.i.d. headlights om my 97 blazer, upon turning them on only one or the other will turn on, however if I rev the vehilcle some to get more current flowing and try numerous times turning switch on/off ,on/off they will both eventually fire up. Now,I changed my battery from a 550 cc amp to a 700 cc amp one, did not fix problem. will changing my headlight relay to a ''heavy duty'' do the trick? I am aware they only need a boost upon initial ignition, has anyone had this problem and also suggestion ? thanks!
:crazy: oK...seeing no one yet has an answer for me, I just found out after much searching in internet, that in order to eliminate this problem you can either buy a wiring harness with relay and this feeds directly from battery even though you still use your original light switch but you get all of the headlight juice straight from the battery. the harness is about 80.00, or you can make one yourself, which is what im going to do. I have taken the time to post this answer to avoid the searching I went thru for :confused: someone else :cheers:
