Im back in action
illmac77
Well after a few years and a couple Vette's later im back, traded the wifes ford explorer (been trying to get rid of it forever) in for a 05 silver Z71 colorado 4x4. Very well build truck, im glad to be back on the forum with everyone, now its time for the wife to dish out the cash for mods for the truck so i can continue to mod the 04 Z. :chevy:
    Gkistler
    Gkistler
  • Who's Online   2 Members, 0 Anonymous, 893 Guests (See full list)
