Horn Location
I have done a search and can't find the info I need. Trying to find the horn on a 99 Silverado 6cyl 2wd. Horn doesn't work, all fuses are good. Where are the horns at?
Thanks,
AW
Thanks,
AW
Behind the headlamp assembly, on the driver side.
If I'm not mistaken...I think there are 2 horns. The high note is behind the bumper on the passenger side, and the low note is behind the windshield washer reservoir. My high note just went, I'm not positive if the base/V6 2WD has a different horn setup though, :cheers: its worth a look-see.
Only 1 horn on this truck
Really? I gotta go check my '03 now...
I thought they used Hi and Lo notes to create a beat frequency between them to get your attention. Now that you mention it, my '03 is kind of wimpy. Hmmmm... Gotta go check my '03 now...
