10% ETHANOL
MY 04 BURB MAN. SAYS NOT EQUIPTED TO USE ETHANOL (NOT SURE OF SPELLING) IT STATES ONLY ENGINES WITH A CERTAIN VIN CODE CAN USE IT. NOW IM LOOKING FOR GAS WITHOUT IT BUT ITS HARD TO FIND, WHAT WILL HAPPEN TO MY 5.3???
Scott
The 10% blend sold at gas stations in many states is safe for all vehicles so far as I know (had the same stuff when I was living in the Chicago area). It reduced my overall gas mileage by 1 or 2 mpg, but there were no other bad effects that I noticed.
The warning about only certain engines using ethanol is for 100% ethanol. Some of GMs truck fleet are set up for this, but I'm sure any pump dispensing it would be clearly marked as such.
USA is right. All you can buy in MN is 10% ethanol blended fuels for regular unleaded (state law to support the corn growers) so everyone up here runs it with no issues.
What I think your Burb man is refering to is E85. Some GM engines are equiped for it and some are not. If yours is not, I would ask your dealer before running it. As for the 10% ethanol blend, I have run it for years with no problems.
USA1Fan, I am suprised that you lost fuel milage with Ethanol. When I am out of town and have to run "regular" unleaded, is when my milage drops 1-2 mpg. :chevy:
I have had the same results with the ethanol mix, a loss of milage. I have found 2 stations in my neck of the woods that sell straight gas so I have become their loyal customer. The "mix" is supposed to burn cleaner ,but with my experience, at a sacrifice on milage.
Dunno. But all my vehicles went up by at least 1.5 mpg when I was able to switch to non-ethanol blend. Some people also claim that the ethanol blend robs horsepower, but I couldn't feel any difference. (Maybe a dyno might have reflected something, but it's still gotta be relatively small)
Ethanol has less btu's per gallon as compared to straight gasoline. Less btu's means less power per gallon. May not be noticeable in most cases.
DEWFPO
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,163 Guests (See full list)
