Going to the Dealer
I have an 02 K1500 bought used last month with 24,000 miles. Seems more or less ok, but he warranty is out at the end of March, so have all of you run across:
-Drivers seat cover, basic cloth buckets, seems loose or the cloth not attached at the bottom, like the whole big clip came off the rail underneath?
-Drivers side mirror vibrates at speed. I know since the passenger mirror is steady. Do you see the glass loose or the frame?
-After reading about all the trans issues, anything they should be looking for when they test drive the truck. Mine seems ok, is the 4X4 K1500, towing package, snow plow prep with the cooler up front. Old stlye manual 4X shifter.
-Pulls some to the left, had an alighnment aftermarket, they said they made an caster adjustment, but others have come in with Chevy's that just seem to pull.
Thanks and if you have other stuff I should look at, please say so. Basically a good truck, std cab with 8 foot bed.
(It is interesting having had several Ford trucks that just as many folks have auto trans nightmares on the web site boards with each light duty brand - kind of sad for the money spent)
Thanks
Mike :chevy:
Well I am not sure but my 03 seat came loose at the bottom just like you described more than once, fixed it free of charge. As for the Mirror mine shake on both sides if there is a crosswind from the driver side the passenger mirror shakes and if there is a crosswind from the passenger side the driver mirror shakes, the dealer says they couldn't do anything about it. I have been hearing alot about the steering shaft and axle shafts being replaced because of clunks, might check your out.
you should buy an extended waranty! you still can since you truck is under the factory waranty. i use mine all the time.trans, transfer case x2 ,stearing box, seat tracks,alternator,starter .
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 685 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
