Tool Box--No key
As I said in an earlier topic/question, I just bought an '03 Silverado. It came with a tool box, but the guy who traded it in failed to include the key. The only logo I see on the box is SEC. Any ideas how to get a replacement so I can lock up my box?
  • 1 year later...
#1- Does the lock cylinder have a number stamped on the face, ie: CH501 or similar? A locksmith might have the key in stock.
#2- If the box is already unlocked, just pull the lock core out and replace it with a new one.
If you havent fixed this yet shoot me a pic of the lock to my email, I may have some that will fit,I have 3 sets of locks with keys that are new or almost new,one set of paddle handle ones and 2 sets of pushbutton ones, [email protected]
I got these while trying to get my lock/key problem straight with Delta Pro and they kept sending me locks/keys.
