Quadrasteer
GM First to Offer Four-Wheel Steering on a Full-Size Truck as Quadrasteer Debuts on 2002 GMC Sierra Denali
General Motors has taken the industry lead by offering the Quadrasteer four-wheel steering system for the first time in a full-size truck. The innovative system, which makes driving a truck safer, easier and more convenient, will debut on the 2002 GMC Sierra Denali full-size pickup.
Quadrasteer marks a milestone in full-size truck handling and control. It's an electromechanical system that turns the Sierra Denali's rear wheels (up to 12 degrees) in relation to the front wheels, resulting in unprecedented low-speed maneuverability and high-speed stability.
"Quadrasteer is truly a game-changer," said Joe Aiello, Canadian Brand Manager for GM full-size trucks. "Although four-wheel steering has been available in cars, this is the first application in trucks, where the benefits are even more apparent."
Three driving modes
Quadrasteer offers a choice of three driving modes, and is engaged by controls conveniently located on the instrument panel:
"2WS" allows the truck to operate like any two-wheel-steer vehicle.
In "4WS" mode at lower speeds, the rear wheels turn in the opposite direction of the front wheels, which helps the vehicle make tighter turns, such as when cornering or slipping into a tight parking space. Quadrasteer reduces the Sierra Denali's turning diameter by 21 percent, from 14.1 m to 11.4 m (46.2 ft. to 37.4 ft.), which is comparable to that of a Saturn S-Series coupe.
At higher speeds, the rear wheels turn in the same direction as the front wheels, reducing the vehicle's "yaw," or rotational motion, for dramatically better stability during lane changes and when being passed by a large truck.
Quadrasteer also benefits customers who trailer, enabling the Sierra Denali to change lanes with more confidence and with hardly any trailer sway. During low-speed towing maneuvers, such as backing into a boat launch or parking a camper, four-wheel steering greatly improves the trailer response to steering input.
The "4WS Tow" mode reduces the amount of rear-wheel steer at lower speeds and increases rear wheel steer at higher speeds to provide even more stability than regular four-wheel steering.
Maneuverability and stability
"Once you drive the Quadrasteer Sierra Denali, you're a believer," said Aiello. "Combining the truck's 325 horsepower Vortec 6000 V8 and all-wheel drive with the maneuverability and stability of Quadrasteer delivers simply astounding performance. Four-wheel steering is one of many innovative technologies and features within GM's full-size truck portfolio which will provide customers with real benefits while reinforcing brand equity."
Quadrasteer operates by sensing the driver's desired steering input by way of a steering wheel position sensor. This information is fed to a microprocessor that determines the appropriate rear-wheel angles, based on steering input and vehicle speed. The microprocessor feeds its data to an electric motor which, based on algorithms, drives the rear steering rack through a planetary gearset.
If a system failure is detected, Quadrasteer's failsafe mechanisms revert to normal two-wheel steering.
Increased capabilities
With Quadrasteer, the Sierra Denali gets a new standard 4.10 rear axle ratio which increases its Gross Combined Weight (GCW) Rating by 907 kg. (2000 lbs.) to 7,260 kg. (16,000 lbs.) and boosts its maximum trailer rating from 3,946 kg. (8,700 lbs.) to 4,536 kg. (10,000 lbs.) A larger 9.75-inch rear ring gear is used to increase the rear axle's gross weight rating by 114 kg. (250 lbs.) to 1814 kg. (4000 lbs.). The larger rear axle increases the GVW rating 181 kg. (400 lbs.) to 3265 kg. (7200 lbs.).
To allow more turning clearance for the rear tires, the Quadrasteer-equipped Sierra Denali has flared composite rear fenders that give the vehicle a brawny, capable look. Their reinforced reaction injection molded construction also resists dents and corrosion.
The Sierra Denali also adds new safety features, including standard roof marker lamps and fender-mounted clearance lamps. Interior box dimensions remain the same.
Quadrasteer will also be offered as a regular production option on other properly equipped GMC Sierra wideside and Chevy Silverado fleetside pickups after start of the 2002 model year.
    Patrick Fergy
    Patrick Fergy
  • Who's Online   2 Members, 0 Anonymous, 1,260 Guests (See full list)
