Truck Payments
loud_sound_sierra
Im tellin yah it workx and its so worth it
Turn $5.00 into $50,000...read this to find out how!!!
READING THIS COULD CHANGE YOUR LIFE!!!
I found this on a bulletin board like this one and decided to try it.
A little while back, I was browsing through a newsgroup, just like you
are now, and came across an article similar to this that said you could
make thousands of dollars within weeks with only an initial investment
of $5.00! So I thought, "Yeah right, this must be a scam", but like
most of us, I was curious, so I kept reading... I also did an internet
search and found nothing but success stories.
Anyway, it said that you need to send $1.00 to each of the 5 names and
address stated in the article. You then place your own name and address
in the bottom of the list at ..5, and post the article in at least 200
newsgroups. (There are thousands) No catch, that was it. So after
thinking it over, and talking to a few people first, I thought about
trying it. I figured "what have I got to lose except 5 stamps and
$5.00, right?"
Then I invested the measly $5.00 (I use the word "measly" because $5
really is measly compared to the money I have made through the initial
investment). Well GUESS WHAT!!... within 7 days, I started getting
money in the mail! I was shocked! I figured it would end soon, but the
money just kept coming in.
In my first week, I made about $25.00. By the end of the second week I
had made a total of over $1,000.00! In the third week I had over
$10,000.00 and it's still growing.
This is now my fourth week and I have made just over $42,000.00 and
it's still coming in rapidly. It's certainly worth $5.00, and 5 stamps,
I have spent more than that on the lottery!!
Let me tell you how this works and most importantly, why it works....
Also, make sure you print a copy of this article NOW, so you can get
the information off of it as you need it.
I promise you that if you follow the directions exactly, that you will
start making more money than you thought possible by doing something so
easy!
Suggestion:
Read this entire message carefully! (print it out or download it.)
Follow the simple directions and watch the money come in! It's easy.
It's legal. And, your investment is only $5.00 (Plus postage)
IMPORTANT:
This is not a rip-off; it is not indecent; it is not illegal; and it is
virtually no risk - it really works!!!! If all of the following
instructions are adhered to, you will receive extraordinary dividends.
PLEASE NOTE:
Please follow these directions EXACTLY, and $50,000 or more can be
yours in 20 to 60 days.
This program remains successful because of the honesty and integrity of
the participants. Please continue it's success by carefully adhering
to the instructions.
You will now become part of the Mail Order business. In this business
your product is not solid and tangible, it's a service. You are in the
business of developing Mailing Lists.
Many large corporations are happy to pay big bucks for quality lists.
However, the money made from the mailing lists is secondary to the
income which is made from people like you and me asking to be included
in that list.
Here are the 4 easy steps to success:
STEP 1:
Get 5 separate pieces of paper and write the following on each piece of
paper "PLEASE PUT ME ON YOUR MAILING LIST."
Now get 5 US $1.00 bills and place ONE inside EACH of the 5 pieces of
paper so the bill will not be seen through the envelope (to prevent
thievery).
Next, place one paper in each of the 5 envelopes and seal them. You
should now have 5 sealed envelopes, each w
