How about 170mph in a go-kart?
MCourson
http://bgvrace.supremeserver20.com/BRC/
This was at our national race earlier this month on board a 250cc Unlimited twin superkart.
My fast time was a 1:37.609
His was 1:10 :ughdance:
A magazine did a comparison at Laguna Seca a while back with a superkart, an Indy car and a Z06 Vette. The vette got its ass kicked, and the superkart was about 2 secs slower than the Indy car.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
