New guy from Aggieland
willieboy
Howdy all. Just thought I would stop in and introduce myself. I currently reside in Bryan, TX. Right now i am driving a Dodge Dakota, but I am looking to move on to a '02/'03 Burb. Any advice or buying tips is appreciated.
Why you going from a big jump up to a Burb.
Well, we buy vehicles to last for 5-7 years. When we bought the Dakota, we had no family or plans, no dogs, and no camper. Five years later we have a camper, two dogs, and kids on the horizon, as well as plans to upgrade to a larger camper (popup to a travel trailer). So, it seemed that with teh camping gear, two dogs and a couple of kiddos, a crew cab truck or smaller SUV could get full in a hurry.
I have always liked the Burbs, but could never justify owning one. Well, now we have the reason and desire, so here we come.
Subs are good bull willieboy.  :(   What are some of the things you are concerned about this most noteworthy purchase?
Mostly are there any trouble spots to look out for. On Dakotas it is brake rotors, ball joints and timing chains.
Also are there any particularly bad years? Are there any very good years?
Lastly, what are the axles codes (4.10/3.42, locking/peg leg), and where do I find them listed on the Burbs?
Thanks for any help.
    Sothpaw27
    Sothpaw27
  • Who's Online   4 Members, 1 Anonymous, 652 Guests (See full list)
