replacement torsion bars
I'm wanting to replace the torsion bars on my 1/2 ton z-71 with some heavier ones. Does anyone know which ones could I use?
I've got a few different codes, and can not decide.
ohhh my truck has xm bars with green keys
Thanks!
Thanks!
It all depends on how much weight you want to put on your front end or how stiff a ride you want. If you just want to raise the front with Green Keys then I wouldn't bother changing anything. If you want a stiffer front end or you are planning to put some extra weight on the front(Winch,etc) or your stock XM's are worn then you can go up to the next torque rating. Your XM bars have a 5638 ft/lbs rating, the next ones up are the GF-(5826 ft/lbs)P/N-15528955(LH) & 15528956(RH) or the YH-(5913 ft/lbs) P/N-15058267(LH) & 15058268(RH). These bars are about $124.00 each at GM parts direct. If your stock XM bars are toast and you don't plan on adding any extra weight on your front then you could always get another set of XM's. I hope this helps :devil:
Don't use green keys on your half ton as you will not gain anything over your stock keys ( they're the same ).
The HD trucks are what take the green keys to see lift, you need Ford torsion bar keys to achieve the same effect.
:seeya:
    appletrav
    appletrav
  • Who's Online   5 Members, 0 Anonymous, 288 Guests (See full list)
